    CentOS2Alma discussion
  • Inviting everyone to the UX test of a new security feature in the WP Toolkit
    For WordPress site owners, threats posed by hackers are ever-present. Because of this, we are developing a new security feature for the WP Toolkit. If the topic of WordPress website security is relevant to you, we would be grateful if you could share your experience and help us test the usability of this feature. We invite you to join us for a 1-hour online session via Google Meet. Select a convenient meeting time with our friendly UX staff here.
Resolved Upgrade Problems
KlausZ
Basic Pleskian
CentOS 7.9.2009
18.0.48
tonight the server panel on a centos-server want to upgrade automatically. I got a error mail:
Plesk Installer 3.48.0 (revision 9ca31ed3b9c9) started at (timezone CET) Thu Jan 19 02:01:07 2023 Command line arguments: /usr/local/psa/admin/bin/autoinstaller upgrade plesk 18.0.49 --email [email protected]
Try to find rcfile...
Autoinstaller found rcfile at /root/.autoinstallerrc Update operation was locked by another update process.
I follow this article and kill the process: Unable to open the “Updates and Upgrades” page or start Plesk Installer in CLI: Update operation was locked by another update process - Support Cases from Plesk Knowledge Base
But after i make the manuel installation i got this error:
[2023-01-19 12:06:02.888238] The following packages from not selected components will be installed because they are required by other components' packages you selected for installation:
[2023-01-19 12:06:02.894983] Pakete werden installiert
[2023-01-19 12:06:02.898662] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_49', sequence='prep', stage='execute', sequence_order='-2', operation='install', exec_cmd='touch /var/lock/plesk-report-update.flag; :'', m_arch='', exit code: 0, output: ~empty
[2023-01-19 12:06:02.903886] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_49', sequence='prep', stage='execute', sequence_order='-1', operation='install', exec_cmd='touch /tmp/pp-bootstrapper-mode.flag; touch /var/lock/parallels-panel-maintenance-mode.flag; rm -f /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', exit code: 0, output: ~empty
[2023-01-19 12:06:03.000184] Another instance of bootstrapper is already running. Please wait until it finishes.
If you are completely sure there is no other instance running,
just remove /var/lock/parallels-panel-bootstrapper-running.lock file and retry.
Note: running more than one instance at once may badly damage your system.
Bootstrapper has finished action (exec time: 1 sec.): parent_name='panel', sequence='prep', stage='execute', sequence_order='0', operation='install', exec_cmd='/usr/local/psa/bootstrapper/pp18.0.49-bootstrapper/bootstrapper.sh prep-install BASE'', m_arch='', exit code: 1, output: ~empty
[2023-01-19 12:06:03.009279] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_49', sequence='prep', stage='rollback', sequence_order='1', operation='install', exec_cmd='rm -f /tmp/pp-bootstrapper-mode.flag; rm -f /var/lock/parallels-panel-maintenance-mode.flag; rm -f /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', exit code: 0, output: ~empty
What can i do? I dont want to reboot the server?
The first warning message "Update operation was locked by another update process." already indicated that another update process is running so a second one won't start. That is perfectly fine. Normally, simply wait until the running processes completes.
Now as you followed the article that describes how to stop a running Plesk installer process, you may have stopped running Plesk installer processes, but this does not say that it stops all system update processes.
On a new attempt you again got the information "Another instance of bootstrapper is already running. Please wait until it finishes." probably the system is right that there is another unfinished process. You will need to find out what this is before you continue, because "If you are completely sure there is no other instance running, just remove /var/lock/parallels-panel-bootstrapper-running.lock file and retry. Note: running more than one instance at once may badly damage your system." And that is a valid warning. There is not much else you can do but to examine the processes in Linux if there are other update (yum) processes running and what these are doing or why they have not yet finished.
thanks for the answer.
ps -aux | grep yum |grep -v grep = nothing
ps -aux | grep install |grep -v grep =nothing
How can i check if another bootstrap Process is running
I found in /var/lock/parallels-panel-bootstrapper-running.lock . The date is from 17/Nov/22. Thats was the last Update from plesk:
Plesk Obsidian
Version 18.0.48, zuletzt aktualisiert: 17. Nov. 2022 06:44:28
May be thats the problem, that this file is not deleted correctly? Can i delete it, or should i make a reboot?
Thanks a lot, Klaus
I do not want to advise deletion of the lock, because I am not looking at the server. There could be a million reason why there is something critical going on. Did the last update finish properly according to /var/log/plesk/install/autoinstaller3.log? If it was my own machine, I'd probably go ahead, delete the lock file and then run a yum update / upgrade, and I'd feel scared doing it anyway. If you are unsure about what to do, I can only recommend to let Plesk support look onto the system, because they can examine it right on your machine and are also standing by in case there are issues when you or they attempt the update again.
ok - i do a reboot. After that the file /var/lock/parallels-panel-bootstrapper-running.lock was deleted. I can make the update successfully.
Thanks a lot.
Klaus
